Speed INC inline fuel pump!
Old Mar 7, 2003 | 06:12 PM
ANIL8U's Avatar
Default Speed INC inline fuel pump!
Its a 255 inline pump. is anyone running this pump? Pros and Cons? Thanks
Old Mar 8, 2003 | 02:03 AM
parish8's Avatar
single digit dreamer
Default Re: Speed INC inline fuel pump!
i got one, i can't give you an exact hp but i have ran 8psi on a 6.0 with a 10.5a/f ratio and have also ran 6psi with a 35 shot on the same motor. i watch the fuel presure and it holds steady the entire run.
i have heard that these inlines are noisy but i can only hear it when i am pulling out of the garage with my window open.
Old Mar 9, 2003 | 09:40 PM
Ken G's Avatar
BTW, I ordered that pump from Speed Inc. and it is the Walbro unit. Mine is very quite too.
-Ken
Old Mar 11, 2003 | 08:34 AM
Big Stick's Avatar
This may be a dumb question, but...
If you run an inline pump such as the Walbro, do you need to add an external pressure regulator as well? If not, how is the pressure regulated?
Old Mar 12, 2003 | 04:50 PM
parish8's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by NDR PRSR:
<strong> This may be a dumb question, but...
If you run an inline pump such as the Walbro, do you need to add an external pressure regulator as well? If not, how is the pressure regulated? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">\
HMMM, never thought of that, mine is on a truck and we have the regulator on the rail.
Old Mar 19, 2003 | 10:27 PM
ANIL8U's Avatar
Can you run the inline pump all the time or do you need a hobbs switch?
Old Mar 21, 2003 | 01:19 AM
JimmyKash's Avatar
no, ALWAYS run both pumps at all times unless you make a separate fuel line for the inline with a checkvalve
if you try to make your intake pump push through the in-line, you'll kill both
Old Mar 21, 2003 | 07:33 AM
Mike 00'SS's Avatar
I too have the inline pump from Speed Inc. and it IS a Walbro 255lph..it seems to be working just fine for my needs but it is quite loud. ( I can hear it over my T1 and loudmouth at ldle)
Old Jun 16, 2007 | 03:57 PM
81LS1Camaro's Avatar
I know this is a way old thread, but I have the same question.
