Confused about stock fuel system
I'm trying to figure out how our stock fuel system works on my wife's '02 SS. I'm a mustang guy who's doing his first f-body mods.
Are all the LS1 fuel systems returnless?
From what I understand on these returnless systems there is a regulator in the tank. Does the regulator adjust for manifold vacuum/boost?
Thanks,
Steve
I noticed some kits come with an FMU. How do they work without a return line?
The idea of tuning for boost without a constant fuel pressure across the injectors is.. uh.. wow.
The computer injector flowrate tables compensate for vacuum, but not boost. The map sensor is only good to 1 bar (atmospheric pressure). You can remove the stock one and install an adjustable vacuum/boost referenced one outside at the engine or were the electrical connections are for pump (just ahead of the wheel well)
Gary
Gary
I've figured it all out now though. Thanks!
Steve
