Fuel pump cutting out
Old Apr 1, 2003 | 09:14 PM
Ferrell's Avatar
Default Fuel pump cutting out
Anyone have ideas about what could cause this behavior? After running for 20-60 minutes my fuel pressure drops and the car shuts off. After sitting for a while it will repeat this. Is this the FP going? Also, can the PCM cut power to the FP through the grey wire from the relay (FP signal from PCM) and why would it do this after running for a given amount of time?
Any suggestions appreciated,
Ferrell
Old Apr 2, 2003 | 05:04 AM
blown 346's Avatar
Default Re: Fuel pump cutting out
You're pump could be on it's way out. My buddie had the same problem, he found out that the ground for the pump was loose and caused his to go in and out whenever it felt like it. The ground is located behind the driverside head, you will see the ground wire there.
