P0300 and lean both banks due to bad injectors?
I installed new injectors on my intake when I put my 408 in, I used 8.1L truck injectors. I planned on upgrading later on but figured that these would be enough to get me through the engine break in.. Well after firing it up I get codes of random misfire(and it feels like it is misfiring, shaking, etc) as well as lean on both banks. Would this be the result of stuck/clogged injectors? They did sit for a few months before the motor installation.
Think these buggers are the culprit in my misfire/lean engine problems?
-Lurius
-Lurius
Not much info to go on. you can listen to them with a stethoscope. If they aint clickin they're stuck. Now if the are clickin, it still doesnt mean they're good. They could be plugged. But if some aint clickin thats a dead giveaway. Get a mechanics stethoscope. Or take them to someone who can test/flow test them.
