Injectors?
Old May 22, 2007 | 10:40 AM
05 GSXR 1XXX's Avatar
Default Injectors?
i did a search on the SVO green top 42# and was wondering if anyone has had any problem with these,
looks like there rated no more than 540hp??
im building my t66 turbo Ws6 for no more than 550rwhp would these be a good match?
please respond asap
Old May 22, 2007 | 10:52 AM
98turbls1's Avatar
I would honestly go with 60lb injectors... You can find them for almost the same price and if you ever want to bump up the boost you can without having to the same thing twice...
Old May 22, 2007 | 10:56 AM
SonofaBish's Avatar
i agree...
plus, w/e HP you say they are rated at, is most likly flywheel hp... no whp
Old May 22, 2007 | 11:03 AM
Im just scared about running such high injectors becuase of running rich, but that shouldnt be a problem as long as the tuner does right A/F correct?
Theres no a saying like you cant go wrong with to big of injectors is there? lol
Old May 22, 2007 | 11:18 AM
98redorangeta's Avatar
your gunna need to run a lot of fuel pressure like 85 psi to make them support 550 rwhp. so i would get 60#
Old May 22, 2007 | 11:23 AM
well it looks like 60# for me!
one more question, yall say needs high pressure, is the 255 walbro pump going to be enough?
sorry for all the random question, i just pland this out for 42# and 255 just making sure.
Thanks
Old May 22, 2007 | 11:37 AM
smokinHawk's Avatar
i used the 42's for 550rwhp (dynojet) no problem and you can usually find them used for a good deal ($200-$250)
id just get the 42's if you can find them cheap and dont need more then 550rw
Old May 22, 2007 | 12:01 PM
I thought you were running 60s on your car?
Well i have seen his car go pretty good and if it was on 42s then thats all you need i just went by the caculator in the sticky.
Old May 23, 2007 | 06:58 PM
Emuffinman's Avatar
I have some 42 lbs./ hr. Seimens injectors with only 500 miles on them. You can have them cheap. Paul
Old May 25, 2007 | 04:50 PM
gts500's Avatar
i need 42# how much u gonna sell it???
Old May 27, 2007 | 01:02 AM
Mike @ New Era's Avatar
With the 60's you'll never run out of fuel , we have them for $399 and in stock and you can also get them flowmatched from us as well with a data sheet ! #42's is cuttin it close !
Mike
