turbo stroker injectors?
Old May 26, 2007 | 10:26 AM
SS101's Avatar
Default turbo stroker injectors?
i'm building a twin turbo 427 ls1, i'm using a walbro eliminator pump w/ controller, sumped tank and looped fuel system so i don't think i'll be running out of fuel - what size injectors would be enough/more than enough??
Old May 26, 2007 | 01:00 PM
Ping King's Avatar
there are injector tables out there. First you need a realistic guess of your power output
Old May 26, 2007 | 03:19 PM
ZL1Killa's Avatar
need to know that. and at the top of this section: you will find a link to an injector calculator. or it can be found here:
Please note:
Most injectors will max out at 80% duty cycle and this is the accepted industry standard.
I did not make this up! This is from SAE - Society of Automotive Engineers.
The website article is http://www.rceng.com/technical.htm
and of course the website is http://www.rceng.com
