Injector Question
Old May 1, 2003 | 07:20 PM
SunsetWS6's Avatar
Default Injector Question
I'm getting a TR 224/224-112 cam installed & I already have LT's & lid etc. I was talking to a guy who works at a shop & he said something about getting larger injectors. I didn't think larger injectors were needed. Are they?
Old May 2, 2003 | 06:31 AM
CamM's Avatar
Default Re: Injector Question
You won't need new injectors with just a cam and bolt-ons. When you approach 450rwhp then you need to start thinking about upgrading.
Old May 2, 2003 | 03:02 PM
horist's Avatar
I think it depends on the year of your car... once it's all installed get it attapped or dynoed w/wideband.
If atap indicated >80% injector utilization you'll wanna upgrade, or if the car is running really lean on the dyno and they can't get it to run any richer.
I believe it's 98, 01 and 02 have 28lb/hr injectors whereas 00 and 99 have 26.5 lb/hr injectors, so the 99-00 are at a somewhat disadvantage on how much power before new injectors are needed.
Old May 2, 2003 | 03:37 PM
Team ZR-1's Avatar
Not a chance, even with a stock engine a 26 lb injector could only
handle a peak of 416 HP at flywheel and even then that would be at
a 100% duty cycle so at 80% it is only 333 HP and most cars even with
a few mods would exceed that.
Ability of Your Injectors IF 26 lb/min
FWHP 416 Duty Cycle 100% <b>333 @ Duty Cycle of 80%</b>
<b>RWHP 354</b> 283
Using a BSFC of .50
Add some hot weather, some mods and with stock injectors
would be knock city.
Old May 3, 2003 | 08:33 AM
CamM's Avatar
[quote
<b>RWHP 354</b> 283
Using a BSFC of .50
[/quote]
I agree, but SunsetWS6 has a 2001 with 28# injectors not 26#s.
Old May 3, 2003 | 05:39 PM
Team ZR-1's Avatar
[quote I agree, but SunsetWS6 has a 2001 with 28# injectors not 26#s.
[/quote]
28 lbs still would not support 450 HP at rear wheels >
Ability of Your Injectors IF 28 Lb/min
FWHP 448 Duty Cycle 100% 358 at Duty Cycle of 80%
RWHP 381 305
