cutting a trap door?
Old Jun 22, 2007 | 08:45 PM
ls2 bait's Avatar
Default cutting a trap door?
what are u usong to do it? almost seems as though a cutoff wheel would throw too much sparks around that whole flammable liquid that is is there
Old Jun 22, 2007 | 09:35 PM
ZL1Killa's Avatar
u really trying to do the trap door?
i honestly think its easier to drop the tank...i did mine.
Old Jun 22, 2007 | 10:09 PM
SS SLP2's Avatar
(Post #1)
Fuel Pump Access Door Installation
http://www.geocities.com/formulapower2/fuelpump.html
That link should tell you all you need to know!
Not as detailed as that but this is another source:
http://www.ls2.com/forums/showthrea...p;threadid=1792
E
__________________
Old Jun 22, 2007 | 11:14 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Originally Posted by SS SLP2
(Post #1)
E
__________________
Neither of those links work. I'd like to see this too.
Old Jun 23, 2007 | 07:33 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I used a cutoff wheel on mine with no problems. Yeah, there were sparks, but you can control where they go by angling the wheel. Most the sparks are in the cabin and not underneath.
Old Jun 23, 2007 | 09:40 AM
bygblok's Avatar
there's no flammable liquids exposed in that area unless you have a fuel leak. If that's the case you have more problems than just a pump. There's a couple of good articles with measurements etc. that have been posted over on www.thirdgen.org if you want to do a search.
Old Jun 23, 2007 | 01:54 PM
SPRAYED 01's Avatar
I used a dremel. Worked very well.
Here is a fun little video i make when i was done.
Enjoy!!!!!!!!!!!!!!!!
http://video.google.com/videoplay?do...14589991027401
Old Jun 24, 2007 | 08:05 PM
InjectedSS's Avatar
Are you kidding me? No way having the trap door is SOOO much better. Especially if you gotta swap your pump out anytime down the road it will be that much faster the next time around because you will already have an access panel cut.
It's way simple to do I don't know why people make such a fuss about it. **** almost all new cars come with an access panel for the fuel pump. I used a big 4" grinding wheel when I cut mine because it was taking way too long using small little dremel cutoff wheels. Just gotta be careful not to let the disc go too deep. I didn't have any problems though.
Old Jun 24, 2007 | 10:01 PM
SPRAYED 01's Avatar
As ive stated in the past on this topic, we modify everything on our cars to make them better. Its better to be able to get your pump out in 5 minutes. Why not do it? I could understand if it was a totally stock car that was rare. But for modified cars that might need diagnosing every once in a great while its a good idea.
Old Jun 25, 2007 | 01:15 PM
Frost's Avatar
Here is a thread with pics of where I cut and what I did... it's in the sticky at the top of the forum: https://ls1tech.com/forums/fueling-injection/615108-my-twin-walbro-s-01-t-pics-schizz.html
Old Jun 25, 2007 | 01:45 PM
SmaknaSS's Avatar
If you do do the trap door method, Make shure you know where the general location of your fuel pump is before you cut! You fuel pump might be in a different location than that LT1 Racetronix link.
Old Jun 25, 2007 | 02:18 PM
jg_98ghost's Avatar
the tarp door works great and its pretty quick and simple. i used a dremel also and has alot of sparks but nothing happened. im glad i did it especially when my fule pump went out 2 weeks after i put it in. just make sure you know where your cutting and dont get ahead of yourself
Old Jun 25, 2007 | 02:43 PM
the_merv's Avatar
Veteran: Air Force
That Flammable Liquid that is enclosed in a Tank and sealed off...
If you cut it without cutting the Lines then you will be alright..I had about 3/4" clearance..
