Can't turn the ring
Old May 9, 2003 | 04:46 PM
MikeB's Avatar
Default Can't turn the ring
How do you turn the locking ring to release the fuel pump canister. I've tried impact and it will not budge. I didn't want to bend the tabs up. Any special tool or technique?
Old May 9, 2003 | 06:18 PM
Chris99WS6PWTMET's Avatar
Default Re: Can't turn the ring
Hammer and screwdriver. Dont be scared of it. Just be careful not to put a hole in the tank.
Old May 9, 2003 | 06:37 PM
MikeB's Avatar
Yeah, especially the plastic tank! I worked on it for awhile with no luck and I wasn't shy! There must be wrench for this ring, I'll have to check. Thanx for the response!
Old May 10, 2003 | 09:46 AM
Not sure about a special tool. I've done 4 99+ tanks using a hammer and screwdriver. You have to whack it pretty good, but it'll move.
Old May 10, 2003 | 01:50 PM
MikeB's Avatar
I wonder if it is because the tank is installed and I'm having to hit it at a steep angle instead of normal to the direction of movement? In any event I've whacked it pretty good and it will not move past the tab indents. There is such a thing as "fuel pump sender locking ring removal tool" mentioned in most internet directions for changing an in-tank fuel pumps. I'll beat it some more and then call the dealer Monday if I don't get it off. I hate to bend the tabs up because I know they'll need to be beat back down and the mounting surface (plastic) is flexible.
