Green top injectors (42lb svo) are they the same?
are these injectors the same found in some mustangs. THe green tops?
I need one injector and can get it off a ford engine, are all the green tops the same? will the work?
also might get a source for selling the 42lbs fairly cheap.
Well... I can only tell you what I know about these injectors on Turbo Buicks.
The "Blue Tops" (36lb @ 42 psi) "SVO" injectors
The "Green Tops" (30lb @ 42 psi) (almost sure about this one)
Anyway, I am sure the green tops are lower PPM than the blue.
I would ask over at the Turbo Buick message board. These guys are real knowledgable on injectors. They change out injectors as fast as we change underwear!
Ron,
Ron,
