Fuel Pump going out????
thanks
Change the filter - tip upside down and hold a lighter close. If it flames you are good, if it doesn't = water from bad gas or condensation.
Adjust TB blade and idle to see if it smooths out.
Doesn't sound like the pump per se, if you are hearing it when you turn the key then it could be something else.
