Installed new pump..
Old Aug 8, 2007 | 10:42 PM
mellowyellow's Avatar
Default Installed new pump..
Just installed new pump , hot wire kit , and modified the fuel bucket...
At idle and normal cruise speeds pressure is at 60psi but WOT at about 6200 rpms it dips down to between 56-58 psi... Is the ok ?
Thanx...
Old Aug 9, 2007 | 12:28 PM
Spitz's Avatar
what's the hot wire kit do? i'm going to be replacing my fuel pump here in the next few days. also any recommendations on fuel pumps?
Old Aug 9, 2007 | 03:32 PM
STALL UP's Avatar
I would not worry about a 2 to 4psi drop my car started to go between 6-8psi drop that is when I went with a boost referenced return style fuel system.
Old Aug 9, 2007 | 04:42 PM
shoemike's Avatar
what pump do you have?
because i have the walbro 255 and i see 70psi at the rail.
Old Aug 10, 2007 | 03:03 PM
Tiger2o69's Avatar
70? I have not heard of that much w/o a boost ref regulator.
Old Aug 10, 2007 | 09:16 PM
Its a kit that runs a wire from the pump to the Batt to keep it at full voltage at WOT...
Old Aug 11, 2007 | 12:24 PM
blownws6_nc's Avatar
I always heard as long as it don't fall below 54 psi @ wot it was ok.
Old Aug 11, 2007 | 05:49 PM
Spitz's Avatar
thanks man! i found the answer while researching my pump decision. going with the racetronix system!!!
