speed inc quick disconnect
Old Sep 1, 2007 | 08:46 PM
purdueranger's Avatar
Default speed inc quick disconnect
How is the quick disconnect supposed to stay on the hard line in the fender well? mine doesn't want to stay down on it.
Old Sep 2, 2007 | 01:23 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
are you missing the little plastic clip by chance?
Old Sep 2, 2007 | 04:29 PM
no i have that, it is keeping the plastic piece onto the hard line. mine just wants to slide off really. i almost want to glue it onto the metal line.
Old Sep 2, 2007 | 05:11 PM
DanZ28's Avatar
Mine was a tight fit also, had to push pretty hard to make it seat. Don't glue it. Make sure the plastic clip is spread outward when fully seated.
Old Sep 2, 2007 | 10:06 PM
marv's Avatar
Put a little oil on the o-ring inside. It'll help the fitting to "pop" into place...
Old Sep 5, 2007 | 08:42 PM
Well I got the plastic disconnect to go onto the hard line but the blue AN fitting that goes over the plastic disconnect wants to move toward the two sides that don't have plastic clips holding it in. is there supposed to be a rubber o-ring that will seal up the fitting to the hard line?
Old Sep 6, 2007 | 01:54 PM
beaSSt's Avatar
When I installed mine I just pushed the AN quick connect fitting onto the hardline.
From your last post it sounds like you took the plastic disconnect out of the metal housing. Am I reading that correct?
Old Sep 6, 2007 | 04:09 PM
i took it out to put it on the hard line and then put the fitting on the quick connect.
