Minor Start/Fuel Problem?
Old Sep 5, 2007 | 07:25 PM
7th Darkness's Avatar
Question Minor Start/Fuel Problem?
Recently I have had trouble starting my car. I have to crank and crank, take a break, crank some more, then out of no where it will just start right up.
I have had some minor surging at low rpms, but I figure that this is just a tune issue. But I am starting to think it may be something else?
I have had a new fuel pump replaced this time last year, but have only run my current set-up (sig) for about 6-7 months on the pump.
Just looking for some ideas maybe what could be going on??
Also if I have to get a higher flow pump, I want to get one that does not go in the tank, so if I do get one, do I have to bypass the one in the cell or can I just use the connection for the new pump and leave it be?
Old Sep 6, 2007 | 07:09 AM
DopeFedZ's Avatar
My car was sort of doing that when I first got it. I would have to turn the key forward to on position for moment then crank it. Sometimes I would have to give it a little gas to keep the car on for a sec then after it would be fine.
I just had some stuff powdercoated and I removed the throttlebody and cleaned it real good. After putting it back together my car starts right away. No having to crank repeatedly and I don't have to step on the gas at start up to keep it on.
Old Sep 6, 2007 | 10:11 PM
Think I may have found the problem... busted vacuum line. Going to replace in the morning.
Old May 19, 2008 | 08:26 PM
TRlGGER's Avatar
Which vacuum line was it?
mine does the same thing
Old May 19, 2008 | 09:10 PM
linegtdt52's Avatar
I bet it's that damn vacuum line that connects to the pcv valve to the throttle body. All 3 of mine burned a hole within 3 years and threw me for a loop until I introduce brake cleaner to the top side of the engine! Gotcha biatch. lol
Old May 20, 2008 | 04:37 PM
TRlGGER's Avatar
Gotcha biatch. lol
LOL... that was from the heart.
So brake cleaner helped you find the leak? should i try that?
