evap system
Old Sep 7, 2007 | 06:35 PM
blackbyrd's Avatar
Default evap system
anyone disable the evap system on hi power engines??
how did you do it
Old Sep 7, 2007 | 11:44 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
yes...
Old Sep 8, 2007 | 12:17 PM
blackbyrd's Avatar
so basically you are plugging the evap line into the return???
why not just delete it entirely
Old Sep 8, 2007 | 12:48 PM
ChevyChad's Avatar
Because then I'd have to run a separate line for my return. Why do that when there is already a line there...
Old Sep 9, 2007 | 05:10 PM
blackbyrd's Avatar
i wasnt critsizing (sp) what you did im just asking becasue im replumbing mine with all steel braided and i figured if someone did away with the evap they re plumed the whole system
so you if i was running a feed and a return there would be no need for me to have the evap?
Old Sep 10, 2007 | 09:10 AM
ChevyChad's Avatar
You still want to leave the line from the tank venting to atmosphere, but you can take off everything else if you want. You will also need to have the codes turned off related to the EVAP in the tune.
Old Sep 10, 2007 | 10:05 AM
blackbyrd's Avatar
thats what i figured out yesterday so basicall you just leave the rubber line that goes off of canister to the hard line open ended and let it do its thing but ecm will throw a evap leak code, and i can have that edited in my tune
thanks for all of the help man
Old Sep 10, 2007 | 10:33 AM
cherryelky305's Avatar
I would'nt leave it open ended. Older cars had what you want to do and they used vent caps on the hose ends, so Im sure some kind of vent cap is in order.
Old Sep 10, 2007 | 10:55 AM
blackbyrd's Avatar
vent cap opens up once so much pressure hits it right??
so that basically replace the silenoid under the hood?
Old Sep 10, 2007 | 10:59 AM
I'm not sure, either that or it just stops fuel from splashing out or spilling out.
Old Sep 10, 2007 | 11:11 AM
Ok I went through 10 google pages and came up with nothing, mostly marine applications. Anyway you could cap it with a solid cap then buy a vented gas cap, or you could leave it un capped, my el camino was just venting into the engine bay for several years still I'm going to cap it once im done with the ls1 swap.
Old Sep 10, 2007 | 11:13 AM
blackbyrd's Avatar
im still leaving the charcoal canister on the tank and all the wiring im just eliminating the line from it to the engine bay, fuel doesnt get into the canister, so really there isnt a need for a vent cap then.
Old Sep 10, 2007 | 11:56 AM
ChevyChad's Avatar
just make sure you have some vent for pressure relief
Old Sep 10, 2007 | 12:11 PM
blackbyrd's Avatar
well my plan was just to leave the line that comes out of the cannister and plugs into the line you used for a return and just route it somewhere it can breath and use it as the vent.
that way the system can still do its job it just doesnt dump the fumes into the engine it just releases it under the car.
