injector size ??
Old Sep 8, 2007 | 01:02 PM
razorclaw99's Avatar
Default injector size ??
im going to be maxing out the p1sc with my new motor..its going to be a 383 with 9.25:1 compression with stock heads. im not quite sure what psi ill be running because apparantly its different now that i have a stroked motor..procharger said the pulley size is about a 355. Anywayz, it'll be from 12-14 psi..whasize injectors should i go with..im trying to find a reason to stay away from 60 lbers cuz they r so expensive...
(BTW, THIS IS GOING IN AN LT1, NOT LS1)
any opinions?
