Pressure bleed down time
Old Sep 16, 2007 | 02:42 PM
03 BUSA's Avatar
Default Pressure bleed down time
Search is not working. What is the the fuel pressure bleed time allowment? When I turn my key on it goes up to 59-60 and then when the pump stops running it drops to around 45ish and will continue to bleed down after a couple of minutes. L76 injectors and 255lph Walbro in tank pump. Thanks guys.
Old Sep 16, 2007 | 11:47 PM
Full-Force's Avatar
I take it you replaced just the pump in the bucket assembly. You may want to pull it back out and look at the hose that goes from the top of the unit to the pump itself. I just got through working on a car that I had diagnosed with a bad fuel pump only to find out that when I pulled it out the rubber hose had split aroound the nipple on the top of the assembly aloowing the pressure to bleed.
Full-Force's Avatar
BTW, I would love to see some pics and more info on your car. It looks as if you have a monster setup.
