Fuel pressure bleed down time
Search is not working. What is the the fuel pressure bleed time allowment? When I turn my key on it goes up to 59-60 and then when the pump stops running it drops to around 45ish and will continue to bleed down after a couple of minutes. L76 injectors and 255lph Walbro in tank pump. Thanks guys.
"important: fuel pressure may vary slightly when pump stops running but should stabilize and remain constant." It says monitor pressure for 1 minute after it shuts off and gives a 5 psi drop as acceptable.
If pressure do NOT drop more than 5 psi, then goto step #5 if which is to relieve fuel pressure down to 10psi and monitor for 1 minute, if it drops more than 2 psi (to less than 8 psi gauge) then replace the fuel pump;
or if pressure DOES drop more than 5 psi then it talks about using special tool on fuel rail and removing rail to find the leaky injector.
There are quite a few different steps in the diagnosis, but all use a time of 1 minute for monitoring fuel pressure. hope that helps.
Re'
