1000 hp c5 fuel system
I currently have looked at the A&A system and the ECS system.
Any other options?
Thanks
Has basicly 5 dyno pulls and 5 track passes on it.
Dual intank 340's
8AN sending
6AN return
MagnaFuel billet fuel pressure regulator w/boost ref.
MagnaFuel billet stainless steel fuel filter
Aeroquip -6 braided stainless feed fuel line
Aeroquip fittings .
racetronix wiring harness
This is a complete kit. Take you stock bucket out and install this one.
Only reason I am selling is cause I want to go with a bigger fuel setup.
$1100.00 shipped to your door... Now compare that with what I payed new for everything
If one pump goes down then possible melt down.
I would like to find a single pump system that will be up to the task of 1000hp and be dependable for street driving.
Tim,
Please call me, you never gave me any dyno info on your system. It should feed your car without problem.
If you are set on a single, be prepared to live with the noise & added expense of a pump controller that you will need.
If you wish do discuss these further, I can be reached at (724)322-8505
7:00pm-11:00pm eastern time weekdays & 9:00am-11:00pm weekends.
