walbro problems
Old Sep 22, 2007 | 10:56 AM
455SD's Avatar
Default walbro problems
my 2ond walbro pump is acting up or something else is going on . when the car is warm (does not run hot) fuel stops or has very low pressure once the car is compleatly cooled off it works again. this same situation happened to the first walbro pump after about 700 miles, now after 7 or 800 miles the 2ond walbro pump: same thing. both worked perfect for 700 miles . any body have an idea whats going on ? Please help
Old Sep 22, 2007 | 09:10 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
It would help if you stated what kind of car it was & the model number of pump & the type of installation kit.
I'll try to help you if you give some more information.
Old Sep 22, 2007 | 09:21 PM
procharged355's Avatar
just go over the wiring make sure nothing is grounding out and causing the pump to run warm or lose pressure. If that is not the problem then I would just check the regulator and or go with a different pump
Old Sep 24, 2007 | 08:50 AM
455SD's Avatar
my car is a 98 ws6 pump model # is F20000169 Installation kit amounted to a couple of hoses an clamps and wireing conectors and new sock
Old Sep 24, 2007 | 08:58 PM
LS14Winter's Avatar
My car is doing the same thing! I have a walbro pump in a 2000 Pontiac firebird. Car runs great under wide open throttle, but when rpms are below 1500 it starves and stalls as if its out of gas. Then the car will NOT start until I let it sit for over a minute. Then starts and idles great until hot again.
Old Sep 25, 2007 | 12:18 PM
455SD's Avatar
I have e mailed someone @ walbro for help if I get anything out of him I will post answer, Walbros official answer at this time is "We do NOT make a pump for your application" the F20000169 walbro pump is not for a 98-2002 fbody
Old Sep 25, 2007 | 12:23 PM
455SD's Avatar
oh yeah one other thing I found out the walbro GSS340m is the old style discontinued F2000169
