Injectors for 383 stroker?
Old Sep 24, 2007 | 11:11 PM
Pheonix's Avatar
Default Injectors for 383 stroker?
I have read many searched threads and cant make up my mind. I am running a 383 stroker kit with stock ported heads, cam, headers and stock 99 ls1 intake. I have an aftermarket racetronix pump. I want to know what injectors to run i am planning of a fast 90/90 set up and a set of better heads. Also a 150 shot. What injectors do yall recomend?
Heads= stock 99 ported.
Cam= Mti X1 duration= 230/227 lift=.591/.571 lobe=112
Intake= stock 99 ls1
fuel pump= racetronix
Injectors=??????
Plans fast 90/90, afr heads, and 150 dry shot.
Old Sep 27, 2007 | 11:11 AM
moserman's Avatar
NA=30lb svo's 150 shot= 42lb will be fine
Old Sep 27, 2007 | 11:15 PM
Pheonix's Avatar
Can i run 42's right now thats its NA? Or would it be better to get 30lb svo's and then move up to 42's when i get the gas?
Old Sep 27, 2007 | 11:59 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
You can run 42's now with a good tune.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
