Fuel pump help?... 255 pump Leaking?
Old Sep 26, 2007 | 11:35 PM
Casey2323's Avatar
Default Fuel pump help?... 255 pump Leaking?
I keep having a pressure drop on my fuel system... I took it out tonight and did a pressure check and found a brass fitting on top spraying fuel all over the place??.. guess this is normal... helps cool the pump...
Old Sep 27, 2007 | 12:04 AM
Casey2323's Avatar
I dont remeber my truck bucket having a venturi tube?? ....
Old Sep 27, 2007 | 09:55 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
That pump is designed for a '99 up f-body & is not correct for the truck.
What power level are you at, did it suddenly change pressure or was it always low since the pump was installed?
Is the truck the return or non-return style?
