What brand/model fuel pressure regulator? Need to order ASAP! HELP QUICK!
Damn, I bought this one. Someone please tell me I made a good choice:
http://www.jegs.com/webapp/wcs/store...10002_60236_-1
I bought it from a local speed shop for a good price.
Originally Posted by .ALEX.
more than enough for a na engine, just make sure you run a -8 return, the -6 is a little small.
Aeromotive sells -6 o-ring to -8 male fittings.
The return has nothing to do with how much HP you will make, just a means to keep the fuel cooler.
If you are running a large single you want as large a return as you can to keep the temp down, if you are running a stock/walbro/racetronix then you are fine with the stock system.
tell me if this is a correct route for everything---> -10 feed into the rail(passenger or driverside) crossover(what size?) can i run a FP gauge in the rail? then a -8 return off the regulator? sorry if i sound like a noob im a little new to the fuel area. this is my first big build and i want to make sure everything is done right
Keep away from any sharp 90* bend use as large a radius and free flowing bend as you can, and don't get stuck on braided line, the pushlock line is good to 250psi and the fittings and lines are much cheaper than braided.
