reason for high fuel pressure
Old Oct 2, 2007 | 07:32 PM
shoemike's Avatar
Default reason for high fuel pressure
i have the wahlbro 255 and i am seeing 75PSI at the rail.
what could be the cause for such high readings?
it used to be 60-65PSI.
thanks.
Old Oct 2, 2007 | 09:28 PM
andy670ho's Avatar
Mine is doing the same thing, causing my car to run super rich, shop thinks its the regulator at the pump which the dealer tells me $540 for an entire module to replace.
Old Oct 3, 2007 | 01:36 AM
TheBlurLS1's Avatar
That's what she said...
Maybe your gauge at the rail is jacked up, is the car running pig rich also?
You could pull the sending unit, remove the stock regulator, cut the regulator line outside the tank, and add an aftermarket regulator using some 3/8" compression fittings etc. You'd have a much nicer regulator setup for a lot cheaper than a sending unit.
Old Oct 3, 2007 | 08:20 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I'll sell you my stock regulator for $15 to cover shipping. I'm not using it.
Old Oct 3, 2007 | 10:14 PM
theslow00's Avatar
mine shows 75psi no probs here! i have the 255 and hot wire kit.
Old Oct 13, 2007 | 12:50 AM
shoemike's Avatar
no.
i am running super lean.
Old Oct 13, 2007 | 01:49 AM
Frost's Avatar
Originally Posted by shoemike
no.
unless you were improperly tuned while it was jacked up, you SHOULD be quite rich.
Old Oct 13, 2007 | 07:43 AM
edcmat-l1's Avatar
I would bet he means the fuel trims are way negative, misinterpreting as running lean.
Old Oct 13, 2007 | 10:05 AM
shoemike's Avatar
well the tune was fine then out of the blue it starts to run lean
especially at cold start.
i have had to adjust the IFR rates to compensate for the sudden
high fuel pressure.
maybe i have them too high.
but my gauge is now reading 75PSI
so my IFR is adjusted to that.
2002 injectors are 28.8 LBS/HR right?
