injector question
Old Oct 5, 2007 | 07:45 AM
svtwhat?'s Avatar
Default injector question
i am starting to tune in my ls1. I installed l67 36lb gm injectors and am going to run them at stock fuel pressure. They are rated at the 36lbs at 48-54 though. If i run them at ls1 pressure which is a few pounds higher is that going to make a difference, I am trying to figure out what my injectors would flow @ ls1 stock fp.
Old Oct 8, 2007 | 05:16 AM
LS1MCSS's Avatar
If they flow 36lb @ 48psi, they will flow 40lbs @ 58psi.
