Any Ideas what is causing this
Old Oct 5, 2007 | 11:12 PM
ExceSSive's Avatar
Question Any Ideas what is causing this
Well I ran my best time tonight in the 1/8th 7.86 @ 90.xxx not sure slip is out in the car. Anyway only made 2 runs then took a break to watch, but then on my way home the car started misfiring under a load ...like a freakin' M249...pop...pop...pop . I don't know what it is. I will be checking the plugs this weekend, wires and already added some more quality fuel. We shall see what I find. I wonder if I have some bad gas in it or something.
Old Oct 6, 2007 | 01:09 AM
3.4camaro's Avatar
plug wires.
Old Oct 6, 2007 | 07:14 AM
ExceSSive's Avatar
Thanks for the input...I have to work today but will check it out when I get home.
Old Oct 6, 2007 | 11:56 PM
ExceSSive's Avatar
Well my car may be down until March or sometime around then. Last night on the way home from the track it started missing and giving P0300 code. I limped it home with the TC locking and unlocking all the way barely able to pull up hills and such.
Today I pulled the plugs to see if I had a bad plug...and sure enough 1 of the plugs...good ol' #7 was bent like something hit it...did a compression test and all cylinders were 220 - 230 except #7 was 175 . This is quite a discrepency. I will be pulling the head tomorrow and ordering my new 402 LS2 block sometime around Christmas if my fears are realized tomorrow.
