What is the best Fueling & Injection for this project?
Old Oct 8, 2007 | 03:27 PM
ss2002's Avatar
Default What is the best Fueling & Injection for this project?
LS1 GTO 2004 5.7
Cheater cam,Ported Heads,Forged Pistons,Eagle Connecting Rods
NX up to 250 shot,A4,3.73
What is the best Injectors Size and best fule system for this project ?
95Octane gas
Thank you,
Old Oct 8, 2007 | 04:07 PM
PLucas's Avatar
You would only need a fuel pump if its a wet shot.
Old Oct 8, 2007 | 06:57 PM
theblur98ss's Avatar
I'd say 30lb injectors and a walbro intank and you should be good to go.
Old Oct 10, 2007 | 01:14 PM
Nasty N8's Avatar
What are you making all motor? I guess 450rwhp and then a 250 shot puts you at about 700rwhp one Walbro pump is not going to cut it. I would rec. our stage 3 street kit. Dual Walbro pumps one running the motor and the second would kick on with your nitrous.
-Lonnies/Racetronixs Dual pump setup and installed in your bucket (You would need a core)
-Complete dual wire harness all installed for factory function and fit switch for your nitrous
-NastyPerformance LS1 fuel rails
-MagnaFuel regulator
-MagnaFuel filter
-new -8 feed line
-new -6 return line
-all fittings and hardware to complete the install
Nate
Old Oct 18, 2007 | 02:49 PM
ss2002's Avatar
thanks all but you think the best injectors size 30 ??
Old Oct 18, 2007 | 09:25 PM
ss2002's Avatar
I'll send an email now Nate@nastyperformance.com
