Quick disconnect for feed and return at tank?
Old Oct 18, 2007 | 08:30 AM
PAGregSS's Avatar
Default Quick disconnect for feed and return at tank?
Can I use the Russell 640850 quick disconnect adapter to connect my feed and return line back at the tank to the hard lines that come out of the tank?
Old Oct 18, 2007 | 09:30 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
The lines that come out of the tank are not hard lines, they are plastic. The only hard lines are along the frame rail. The stock feed line is 3/8, and the stock EVAP line (which you can use as a return with a little modification) is 5/16.
Old Oct 18, 2007 | 10:08 AM
Dragaholic's Avatar
9 Second Club NA
Actually, the feed is 3/8".
Old Oct 18, 2007 | 10:23 AM
PAGregSS's Avatar
Originally Posted by ChevyChad
The lines that come out of the tank are not hard lines, they are plastic. The only hard lines are along the frame rail. The stock feed line is 3/16, and the stock EVAP line (which you can use as a return with a little modification) is 5/16.
I have a '98. The lines are metal.
Old Oct 18, 2007 | 09:54 PM
ChevyChad's Avatar
doh yes, you are correct....
thats what I said
