HELP ASAP!!!!!!! How long to start after fuel pump installation! HELP ASAP!
1 Post
I just put a pump in my car and it sounds like it wants to crank over but it just doesn't. I have been trying for like 5 min and the pump starts and primes everytime. This is really pissing me the hell off. Thanks
Fuel, air, spark.
Push the shrader valve, make sure you have pressure.
Make sure you have air going into the engine.
make sure you have spark. pull a plug wire and put a screwdriver in there to arc to the engine block.
Then check your fuses and grounds. Make sure they are tight and corrosion free.
