Fuel pump question not LS1
Old Oct 22, 2007 | 09:15 PM
Deep Blue's Avatar
Default Fuel pump question not LS1
A friend changed the fuel pump in his pickup the other day but when he hooked everything back up to do a test, he says he couldn't get the pump to work. Any suggestions? He changed the pump because the truck wouldn't start and he wasn't getting anything from the injectors.
Thanks!
Old Oct 23, 2007 | 08:19 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
You did not mention the year, but many trucks have a ground wire that goes to the bed. If this wire fails or has a bad connection dur to rust, the pump will not receive power. Check your wiring.
