an fittings???
Old Oct 23, 2007 | 01:54 PM
blackbyrd's Avatar
Default an fittings???
searched and i didnt really see what i was looking for.
when threading the fittings together is there anything you need to make it seal well it didnt come with o-rings so i didnt know if you needed anything
any help would be great
Old Oct 23, 2007 | 03:25 PM
ss1's Avatar
ss1
Nope, they're a 37 degree flare fitting, no o-rings or sealant required.
Old Oct 23, 2007 | 03:27 PM
blackbyrd's Avatar
cool
what about the part that goes into the rails thats 3/8's
Old Oct 23, 2007 | 03:58 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Are you talking about the GM quick push-connect?
Old Oct 23, 2007 | 03:59 PM
ss1's Avatar
ss1
3/8 pipe thread, assuming they're aftermarket rails? I'd use a little teflon tape on them. Some say do, some say don't.
Old Oct 23, 2007 | 04:02 PM
blackbyrd's Avatar
thanks ss1
yes they are aftermarket rails
and is there anything special to do about the gm style quick connect fittings?
Old Oct 25, 2007 | 07:45 AM
ss1's Avatar
ss1
Nothing comes to mind. Maybe lube the o-ring a little bit. It should just click into place.
Old Oct 25, 2007 | 10:03 AM
PLucas's Avatar
Use thread tape for the npt on the rails, i like the liquid kind
Old Oct 25, 2007 | 11:22 AM
bczee's Avatar
Why use the Quick Disconnect Fitting if you don't really need to ? AN Threaded fittings works and seals great and better than the Q/D.
How offen to you disconnect the fuel line from the Rail ? If you have a need, then use the Q/D. my 2 cents...
Old Oct 25, 2007 | 11:48 AM
blackbyrd's Avatar
quick connects are on the tank not the rail
still running factory tank
Old Nov 1, 2007 | 07:54 PM
KHShapiro's Avatar
they do make a cone that goes over the end that can be used on damaged an fitting but i use them on all my stuff anyway. there cheap. goto an aeroquip store or something, they should have them by the hundreds
