l76 injector
Old Nov 1, 2007 | 01:22 PM
blackbyrd's Avatar
Default l76 injector
ok i know that the injector ports are a little larger and the o ring needs to be bigger for ls1 injectors to fit in it, and i know that k tech makes a kit but all i need is the o rings so my questions is can you take the o rings from the l76 injectors and put them on the ls1 injectors and it seal it up well?? (i ask cause i have a friend and the dealership that gets me great deals) so before i run to parts stores with the intake in one hand and the injector in the other going hey this is what i need help me out here i wondered if anyone had tried this?? and i know the cadellac runs the l92 engine but what else is running it right now??
Old Nov 2, 2007 | 12:17 PM
blackbyrd's Avatar
well since no one knows i went to the dealer and got the l76 injector o rings seems to seal it good and once the rail is on applyng force to the seal should be good for those who chose this route part number is 12587147 description is l92 seal kit.
