URGENT, need help with a fuel issue.
Today I got it back on the ground, and started it, then it stalled. I waited a little bit, fired it back up, blipped the throttle a bit and pulled it out of the garage to wash it.
After I washed it I was going to buzz up and down the street a bit and load it up. I get in turn the key, it fires up for a second and then dies.
Now it will not start at all, it's not even coughing like it's trying to start. The reason I think it's a fuel pump issue is the car has a Walbro 255lph fuel pump, and I usually hear it whining when it is running, but right now I'm not hearing the fuel pump run when I turn the ignition on with the key.
I looked at all of the fuses in the block and don't see any blown fuses, and I pulled the cover in the back to check the lines and wiring, which all looks fine.
I need any ideas to try to diagnose the problem, unfortunately I don't have a fuel pressure gauge on the injection, something I plan to rectify, so I don't really know if I have no fuel pressure or not. The way it fired up and ran for a little bit though makes me think it just burned off the remaining fuel pressure already in the lines and now has no fuel pressure.
