Fuel setup for H/C/Juice?
new stock pump in tank
Walbro in-line pump
Scorpion billet fuel rails
Lucas 36# injectors
Fuel Pressure Regulator w/ 1:1
I'll be running some new -6an line where ever needed & using my stock EVAP for a return line. This is probably a little overkill for my set-up, but I want it done good enough I don't have to upgrade again later. I'll be running the FPR b/c our stock system see a dip in pressure at WOT. This should help elminate this.
My system will be almost exactly like ChevyChad on here except he has a dual in-tank set-up. I believe he put a write up on here of his build which included fuel system info.
added...
Here is a link from our local board incase he didn't post it up here.
http://www.ws6zxr.com/showthread.php?t=37650
