? about stock fuel system
Old Nov 14, 2007 | 12:29 PM
KillerZO6's Avatar
Default ? about stock fuel system
i was wondering if 98 + f body fuel system under rate the hp if it gets to low on gas. my friend has a t/a that i borrowed last week and it seems like when its under a 1/4 of a tank that it doesn't pull as hard, it wont spin in second and the power takes longer to kick it(it a a4 car) also doesn't accelerate as fast.
Old Nov 26, 2007 | 10:00 PM
RE AND CHERYL's Avatar
I remember someone else complaining that their car didn't run as well with low fuel, but I don't see why unless it was sucking up air and the fuel pressure was falling off.
Re'
Old Dec 10, 2007 | 11:23 AM
KillerZO6's Avatar
so u think it just from losing fuel pressure
Old Dec 10, 2007 | 09:55 PM
It couldn't be from anything else. The PCM didn't cause it as it dosn't reduce power when the fuel gets low.
Re'
Old Dec 10, 2007 | 10:01 PM
DuronClocker's Avatar
I know if you had a wideband on the car, you'd start to go lean as you're low on gas. Lean enough, and you'll start to get knock and timing retard.
Old Dec 10, 2007 | 10:13 PM
KillerZO6's Avatar
i have wideband o2 on the front 2 and o2 sims on the back 2
Old Dec 10, 2007 | 10:55 PM
MeentSS02's Avatar
Kleeborp the Moderator™
So you are running open loop? What tuning software was used to do this?
Old Dec 11, 2007 | 07:02 AM
wannabess's Avatar
Could be the fuel pump getting hot if there is not enough fuel to cool it.
Old Dec 11, 2007 | 09:57 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Don't run it less than 1/4 tank then!
Old Dec 11, 2007 | 10:21 PM
KillerZO6's Avatar
i never tuned it
Old Dec 12, 2007 | 09:03 AM
MeentSS02's Avatar
i never tuned it
Then you don't have wideband O2 sensors in the front sensor locations...they are narrowband. The PCM can't accept anything more than a narrowband O2 sensor...
