Question about installing a aftermarket Fuel Pump
Old Nov 14, 2007 | 01:02 PM
BadgeZ28's Avatar
Default Question about installing a aftermarket Fuel Pump
I am replacing the existing stock fuel pump with a 255 gph pump. The stock unit has two ports. One is for the fuel output feed line, the second is smaller and goes to a filter on the bottom of the plastic assembly housing. The aftermarket pump only has the large feed output. How do you handle the existing smaller second hose? Thanks
Old Nov 14, 2007 | 03:42 PM
Nasty N8's Avatar
You either eliminate the Jet pump and modify the bucket to keep it full and get the pump to suck from the bottom of the tank...Or you use a direct replacment pump like Racetronixs/full Throttle pumps That retain the jet pump function. Much better route that extends the life and function of your pump.
Nate
Old Nov 14, 2007 | 04:12 PM
BadgeZ28's Avatar
Thanks for the info
