Need some help identifying fuel lines
If anyone could could tell me what each line runs to in what order on the top of the sending unit, on a 98 fuel pump assembly, that would be great. I'm not sure if I could mess anything up or not, but I don't want to fill the tank up with gas if I messed something up, and then have to drop a full gas tank. I decided I didn't want to do the trap door.
Hope somebody can help me out here.
I've got my back end jacked up about 3 feet or more in the air, so maybe I'm just not getting fuel to the pump yet. I've put about 5 gallons of gas in the tank, but the fuel level gauge hasn't moved, and when I tried to start the car (thought maybe I just fubared the level sending unit), it started for a few seconds with 20psi of fuel pressure, then it died.
If the lines weren't hooked up right, would it run at all? Or is the gas just not getting to the pump yet?
