Weird question about injectors, what to buy
Ok, this isn't the usual question about the flow rate size of the injector, but rather the actual injector that will work for me.
I have a 6.0L iron block with an LS6 intake. I switched it from the truck intake and fuel rails to the LS6 intake and LS1 fuel rail. I was planning on getting the 60# Mototron injectors.
Are these pictured the ones I want to get??
Sorry if it's a weird question, but I've never actually seen an LS1 injector, and I was told that the truck injectors are different in physical size and I want to make sure I'm buying the right ones.
Thanks,
Thanks,
I have been told that the plug pig tails are different. Someone told me that if you have a truck plug already, you can get the ls1 car pig tails on summit somewhere. I will try to find it.
LS1TECH Sponsor
You will require the 63's with the minitimer connectors if you are using the factory LS1/6 engine harness.
If you have a harness from a GM SUV with the Multec 2 connector shown below you will need to change the connectors to the minitimer type. We manufacture these connector assemblies in-house. The quality and price can not be beat.
Multec II Connectors
Minitimer Connectors
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
