Will there be a problem mounting the pump higher than the sump?
Old Nov 23, 2007 | 04:12 PM
Snyper's Avatar
Default Will there be a problem mounting the pump higher than the sump?
I think im going with a Magfuel 4302 street pump...the only problem is so far the only place I can find to mount the pump is about 3" higher than the sump..is this gonna be a problem?
Old Nov 25, 2007 | 09:01 PM
RE AND CHERYL's Avatar
Not when the tank is full of fuel, but if the pump was to loose it's prime when the tank was low (or empty), you could have dificulty getting it reprimed.
Re'
