Cam and bolt ons, what injector size to use?
If you ever plan to go with a dry hit of juice or something, I would go bigger. I ran 37s in my 225 cam only auto back in the day, and I run 42s with this heads/cam/N2O setup now. It's good to have room to grow if your going to spend the money.
How does the nitrous effect your injector choice. I am guessing it matters what kind of shot between dry and wet you are using?
My current car, at 446/411, runs perfect with the 42s. I went with the larger injector because of my dry hit of juice. The extra fuel is added through the injectors with a dry kit, and you need enough injector, and pump, to supply a sufficient amount.
It's all in the tuning when it comes to running a larger injector than stock. If your not gonna need 42s, then don't get them. But it's not gonna hurt anything to run a bit larger than needed injector to leave room to "grow", as long as it's tuned properly.
Wet nitrous setups don't rely on the injectors at all, they use a separate solenoid to add the fuel. Choose your injector based on N/A requirements in this case.
Good info, thanks.
The point is, 42# injectors aren't overkill for his setup
