How much power will -8an line support
Old Nov 25, 2007 | 08:26 PM
theblur98ss's Avatar
Default How much power will -8an line support
Just wanting to find out how much power an -8an line will support on a boosted application. I will be running dual bosch 420 pumps with a -6an return and boost referanced regulator.
Old Nov 25, 2007 | 08:45 PM
Casey2323's Avatar
I have the same Question... Are you -8 from the pumps the the tank? Do you have a Y block in back and single -8 to the fuel rails... How about Dual pumps, -8 after the filter 4 feet to a Y block then 2-3' to each fuel rail... Off the rails on the other side into FPR and -6 return ... Sorry to Highjack .. but there are alot of Variables possible...
Old Nov 26, 2007 | 09:35 AM
Jim Craig's Avatar
"in Theory" a -8 line will flow 337 gph, now this is a dead straight line 100ft long without fittings, connectors, etc. Now, in the "real world" I've got customers that have supported up to 1700 hp (single turbo SB Fords) with a -8 line from the fuel pump up to the fuel rails. It all depends on how efficient your fuel system is as to how much fuel it will actually flow.
Old Nov 26, 2007 | 04:44 PM
I'm running -10an from the tank to the pumps and then -8an to Y block and then 8 to the rails
Old Nov 26, 2007 | 04:47 PM
SSilverSSurfer's Avatar
granted Speed Inc has made 1000hp with stock lines im gonna say more than that.
Old Nov 26, 2007 | 06:31 PM
Old Geezer's Avatar
Maybe make the return a -8??
Alot of fuel is returned at low speeds, and idle...
Old Nov 27, 2007 | 08:42 AM
DuronClocker's Avatar
Will both pumps be full-on, or will they be staged where one will be boost-activated (Hobbs switch)?
Old Nov 28, 2007 | 04:14 PM
2nd pump will be on a hobbs switch
Old Nov 28, 2007 | 06:57 PM
mterveen's Avatar
Default more detail on flow please
for the math types:
1) is there a relatively simple formula/spreadsheet to calculate this for gasoline?
2) what "pressure" is this at or doesn't it matter
3) if pressure matters then what is the flow differential between 58psi and 68psi
4) what is the theoretical flow of 3/8 and 5/16 lines, as found on the stock fuel system?
i see lots of stuff about hp that the stock lines can support but i just simply am interested at this point in the "calculated" flow rates.
found this website but not sure about how to determine fuel velocity = http://www.inductionmotorsports.com/
Old Nov 29, 2007 | 08:05 PM
mterveen's Avatar
any fluid dynamics people out there?
