Weldon 2025 questions...
What kind of power can my Weldon 2025 pump support on a built 408/TT setup? Will it support 1200hp at the tires? If I need to run a second pump to reach my power goals... what should I run as a secondary pump with this pump? Im sure if I ran a second pump I would put it on a hobs switch and boost reference it!
ive read of a syclone wiht 1200hp running and some mustang guys with over 1000 running. alot of people were suggesting to step it up to a 2035. talk to nate @nasty hes really a great source, very knowledgable
Call me -- I'm at Weldon and I'll tell you everything you need to know.
The DB2025-A will support 1400 hp (flywheeel) at 80 psi -- what will be your max. fuel pressure (with boost) be?? How big are your turbo's -- 60's, 70's? Is the car driven on the street?
Thanks,
Jim Craig -- Weldon Racing Pumps
440-232-2282
Thanks,
440-232-2282
