fuel rail question/coil covers
i bought an ls6 intake, and need injectors and fuel rails for my conversion (A body) if i use aftermarket fuel rails, how do you attach the coil corvette coil covers-dont they clip on to the fuel rails? its hard to find used fuel rails, and the aftermarket ones are the same price, but i want to use the coil covers
i also wanted to use a diff. pres. reg.-do any factory fuel rails come with out reg-thanks (sure would be easier to go carb.-lol)
i am running a procharger also, w/vette acces. drive
Yes, fuel rail covers clip onto the fuel rails. Not sure if they would work with after market rails. They also clip to the coil pack posts at the bottom. You could try posting in the parts wanted section. Someone should have stock rails they want to sell....
The real question is how big are you going on boost/engine? You might NEED after market rails if your fuel flow is high enough.
That is A dampner in the stock rail not a regulator. If you want some stock rails give us a call We have a set or three laying around
Brent
Exotic Performance Plus
260-244-4808
Brent
260-244-4808
