Help With Injectors!
Old Dec 17, 2007 | 07:49 PM
Disturbed Bird's Avatar
Default Help With Injectors!
im making 450 to the wheel with cam only and bolt ons and im still using stock 28 lb injectors. i do have a racetronix fuel system. i just ordered stage 2 PP heads and i have a ported fast 90/90 im going to be putting on also.
with a retune i should put down close to 550rwhp.
what injectors do you guys recommend with stock cubes?
Old Dec 18, 2007 | 12:06 AM
DuronClocker's Avatar
How are you getting that 550rwhp? Boost? Nitrous? Wet or dry? N/A big cubes?
Old Dec 18, 2007 | 04:12 AM
Zeke34's Avatar
60# High Impendence Fuel Injectors would be my guess if you're gonna be boosted...
Old Dec 18, 2007 | 06:55 AM
Rhino79's Avatar
42's for NA, and would leave you a little room to grow. 60's for FI, but it sounds like you are just doing H/C 90/90. If so 42's will be all you need.
Old Dec 18, 2007 | 11:22 AM
cool thanks. whats the best 42 to go with?
is the 42 svo's good or do they flow differently? should i get the 39svo's?
well i had nitrous took it off 2 months ago. im making 450 right now cam only and bolt ons. ill be running 11.5:1 CR and the cam is ******* big for this motor. so i should be at 550 or a little more from what my tuner is saying. with those heads and the ported fast 90. the cam i have in my ls6 is a 240/244/ 112lsa
