Help Me With Fuel Injectors
My duty cycle for my injectors with my 228/232 .588/.595 cam is 98% So i was thinking that i was going to upgrade to 42#'s. What is a good one to go with? red top or green top or Delphi. Where can i get the best deal on them too?
Thanks
Thanks
i use the ones from racetronix. i believe they are the green tops. you will need to change the injector voltage offset table. they go rich on decel. i found a post saying , i believe 12% decrease, but may have been only 10. once i changed the offset table they worked great. well except for the 185% duty cycle. lol
The 42's would work fine, just make sure they are accounted for properly in the tune..
I'm about to use the GTP injectors (40 lb @ 58 psi) since I have the GM ASA pcm files that uses them, so when I change them the tables will be "correct" for the injectors, and they are cheap if bought used which is a big plus.
I'm actually about to use a cam almost identical to yours with some heavily ported heads and more compression, should be interesting.
42's sound like a little too much to me as well for what you have. You need a good injector that is the appropriate size for where you are at, not for future mods down the road.
Personally, I think a set of 36# SVO's would be perfect. I actually have a low mileage set I am looking to sell for cheep. If you are interested let me know. Even if you are not, I still wouldn't go that big.
How much you looking to let them go for?
I took a moment to go to the sticky. It took me to RC's website and I ran the injector sizing program for you. I used 450hp (flywheel) and it said 30# injectors at 43.5 psi would work for you. Now the red tops (30#SVO) I recomended would flow 36# and leave you plenty of room to grow. As was previously stated to big is not better.
My other question is since my duty cycle is 98% right now. What will the 36#s do? If it lowers it which it should how low will it go and is it a good thing?
So when you buy the SVO 30#s, they are not the 36#s. they get the term 36#s b/c of our high fuel pressure. I just wanted to make sure that i was clear that is all
EDIT: what is our fuel pressure at the fuel rails?
thanks i did the calc too. i too got 36#s. i used 500 crank HP. So we are not to far off.
You could look for Ford lightning 42# injectors on ebay. They can usually be had for pretty cheap. Or look for a set of 36# injectors. Honestly if you can find the injectors you want already used... You can save a little bit of money!
