quick question about svo 30lb injectors
Old Dec 21, 2007 | 08:38 PM
quiet_storm98's Avatar
Default quick question about svo 30lb injectors
Ok i just bought some used svo injectors off somebody but i have a small problem. Today when i got them the caps that are on the end of the injector where fuel sprays out was broken on 3 of them. So i wanted to know if there is a place that sells replacement caps..and if not can they still be used without them?
Old Dec 21, 2007 | 09:30 PM
axeman's Avatar
Mr injector on ebay. I bought a set of 30lb SVO and spent around 20 bucks and I got new filters, o-rings and caps. Plus instructions on how to change the filters. He even sent me a couple xtra parts.
Old Dec 21, 2007 | 09:36 PM
o ok thanks alot..i kinda figured you should be able to buy the caps somewhere
Old Dec 21, 2007 | 11:05 PM
Mike @ New Era's Avatar
If you are worried about anything being damaged , you can sedn them in to us and we can flowtest them , ultrasonic clean them , and replace all orings , caps , and top filters all for $80 and you will also get a flow data sheet with each injector individually labelled so you can place richer injectors in leaner cylinders . The service is available online and then you just send them in to us .
Mike
Old Dec 22, 2007 | 01:04 PM
Mike
o ok thanks for the info..i may look into that
Old Dec 23, 2007 | 07:34 AM
Frost's Avatar
where are you at in VA?
Old Dec 23, 2007 | 03:46 PM
im in northern va..woodbridge to be exact. about an hour or so away from you
