Will #2 sealant work on fuel connections?
I want to put something on the threads of my fuel lines to ensure that the fuel system is leak proof. Will that number 2 non hardening(I used it to seal headbolts on my LT1 enginez)sealant work? It says it resists gasoline..so I just wanted to make sure before I used it.
11 Second Truck Club
I use this stuff for fuel all the time, I like it better than teflon tape. Never had a problem with it leaking. If I am out of #2 then I use rector-seal, which is a plumbers sealer.
As already stated...NO sealer on flare surfaces.
