fuel pressure question
Old Jan 3, 2008 | 05:13 PM
b4c346's Avatar
Default fuel pressure question
hi guys.ran my 75 shot yesterday and 1 time it felt like it worked good and the 2nd time it felt like it was surging. put a pressure guage on the rail and had 38lbs at idle.i think the fpss was doing this due to being set at 35lbs.what is normal pressure for a stock pump.going to check the filter also.any suggestions is appreciated.thanks
Old Jan 4, 2008 | 06:42 PM
RE AND CHERYL's Avatar
Stock fuel pressure is 58psi. It doubtfull the probelm is with your filter because there is very little fuel flow through the filter at idle, if it was plugged up enough to effect it that much at idle it would never get enough fuel to drive. Probably a pressure regulator issue.
Re'
Old Jan 5, 2008 | 09:22 AM
b4c346's Avatar
thanks for your post.come to find out the guage was bad.i tried 2 other guages and got 61lbs. at idle .going to change the filter anyway.
