Cleaners/octane boosters?
Every now and then i pick up like a fuel cleaner/octane boost here and there jsut to help keep my injectors running clean and all the fuel system... here and there ill buy like th 5 $ ones... sumtimes the 8 $ ones... and ive seen some that where liek in the teens..... so i went on jegs and was looking and they have different ones... all rather pricey.... now in my opinion you get what you pay for.... but in this case would buying one of the liek 13 $ ones be better? like if you look on jegs they have various different types... Lucas/redline/permatex/nx express.... but as i looked some state race offroad or street.. is there a big difference over the legal vrs street legal type stuff? liek its a fuel cleaner in all but i dont want to put something in that will hurt my motor.... heres what some of them say... like is this why its more money? and is it a waste of money? like does this effect performance at all?
Nitrous Express Chemical X
Another octane booster? Not Even! Chemical X contains a proprietary ingredient that enhances the power producing effect of your fuel. Chemical X will increase the octane effect by up to 20% in unleaded pump gas, allowing you to run much higher compression without the risk of detonation. A synthetic lubricant in Chemical X is released in every combustion cycle, lubricating cylinder walls, ring faces, and exhaust valve seats reducing wear by over 500%.
Permatex Octane Boost
NOS Street formula will raise your octane by as much as your octane by as much as 3 points, while the Off-Road and the Race formula will increase up to 7 points. The racing formula actually contains a little nitromethane. Get better gas milage and protect your engine against buildup! Oxygen sensor and catalytic converter safe.
Lucas Octane Booster
Lucas Octane Booster - A Real Octane Booster! Tested and proven to deliver three times more boost than most other brands. Lucas Octane Booster is a GENUINE Performance Enhancer! One 15 oz. bottle treats up to 25 gallons of fuel. Not street legal.
eh, i dont waste time with octane boost. used it once and it made my car run like ***. changing the octane effected the tune for a short time.
i do use fuel treatment every now and then though.
lucas fuel cleaner is some badass stuff and comes in a skinny clear bottle and is kinda yellowish. Its only 4.xx per bottle and the p/n MIGHT be 10100... maybe i can't remember.
octane booters are a joke, there is no need to use octane booster b/c is really only boosts it up by .10 so 93 with octane booster would be 93.1. So just buy good gas and call it good. I don't feel like explaining the whole octance thing so we'll just leave it at that.
