Walbro 255
Schwanke sounds like he also has a great alternative....
http://www.roadraceengineering.com/f...pflowrates.htm
UPDATE: I forgot one thing, when using a Walbro pump in-tank with a constant voltage... for longevity it is SUPER important that the Walbro is 50% or more emersed in fuel at all times. They do heat up. If the the tank is ran down close to empty (on most applictions) and the pump doesnt have the fuel level high enough to keep it cool, they can heat up and seize. I ran dual Walbros in my Supra and I have a single Walbro in my TA now... and just to be safe I never let the car get below a 1/8 of a tank of gas. Last edited by Goldfinger911; Jan 17, 2008 at 12:48 PM.
Fuel Pump Size in LPH = 1.2*(3.7854118 *(Crank HP * BSFC factor *(1 / Fuel Weight )))
(Typical premium fuel weighs 6.35 lbs per gallon)
So...
1.2 * (3.7854118 * (700 * .50 * (1 / 6.35 ))) = 250.37 lph
If you are using a Boost-a-pump (like I do) you can just adjust your safety margin accordingly. Read the link I posted above. It gives the Walbro's flow rates at both 12 volts and 14 volts.
